Results 1 to 5 of 5
Thread: [NEW PRODUCT] Mint Snow Foam
    Sydney, Brisbane, Melbourne
    Thumbs up [NEW PRODUCT] Mint Snow Foam
    The new Mint Snow Foam is a super concentrate detergent that produces thick dense snow foam for cleansing the exterior of your car, motor-home, truck, boat or motorcycle.
    It contains a blend of detergents, cleaners and foaming agents for the removal of traffic film, road dust and dirt. Mint Foam is safe on to use on premium waxes, paint protection, sealants and provides ultimate cleaning ability and also contains biodegradable surfactants.
    Mint Snow Foam is ideal as a pre-wash to loosen dirt, and draw larger dirt particles away from the surface of the paint, and in some instances this could be used as a ‘touch-less’ wash’.
    Note: This product is to be used in conjunction with a Snow Foam Lance and for best results we recommend the Autobrite Snow Foam Lance & your High Pressure Washer System.
    From months of extensive testing different brands and types of Snow Foam Washes we have found that this product is most definitely the contender for Autobrite's Magifoam and we did find on our opinion that in some instances it did create more foam and better cleaning ability. And a big plus side, it has a much more pleasant scent than Magifoam! Big thumbs up from CCP team for Mint Snow Foam!
    Remember to use your discount code also to receive 10% off and 500ml, 1L and 5L sizes are available for purchase here
    Car Care Products Australia
    www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
    Sydney - Brisbane - Melbourne
    Feb 2006
    Melborune, VIC
    How much do you need per wash when using a lance?
    Oct 2006
    Quote Originally Posted by dubstar View Post
    I use about 75ml-100ml for 1L bottle. Depends on how you mix it i suppose? If you use more, thats your choice but not needed for results?
    Feb 2006
    Melborune, VIC
    Wow, 1:10 isn't great concentration rate. hmmmmm, will need to think about that on a 'price per wash' basis.
    dubstar,
    As fuzion mentioned, we would recommend approx 50-100ml in a 1 Litre bottle - mix the other remaining with warm water.
    1 x 1L Bottle Diluted should give you 2-4 cars per snow foam pre-wash.
